Autor Tópico: Placa pcb método termico  (Lida 5624 vezes)
Offline grounyx
« Online: 23 de Novembro de 2011, 11:10 »
Tava pesquisando sobre o método térmico que parece não ser muito difícil de implementar. Encontrei na net vários artigos sobre o assunto, mas um deles me chamou a atenção. Um kit chamado "pcb fab in a box", ele é composto por um papel glossy especial e um outro filme que adere ao  toner.
Vou posta as figuras.
http://ultrakeet.com.au/graphics/images/pcbtutorial/loadprinter_a4.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/CDcontroller_artwork.gif
http://ultrakeet.com.au/graphics/images/pcbtutorial/printedArtwork_a4.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/tts_unpacked.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/tts_cut.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/tts_prePrint.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/tts_postPrint.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_precut.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_postcut.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_tts_facedown.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_tts_facedown_taped.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_tts_facedown_taped_laminator.jpg
ali usa um laminador mas pelo que eu li da para usar um ferro de passar também.
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_tts_immersed.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_tts_immersed_removed.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_tts_immersed_rinsing.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_drying.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/pcb_dried.jpg
Agora que vem a parte diferente em relação a aos outros métodos.
http://ultrakeet.com.au/graphics/images/pcbtutorial/trf_unpacked.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/trf_boardplaced.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/trf_insuperfuser.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/trf_peeled.jpg
O negocio adere somente ao toner ..
http://ultrakeet.com.au/graphics/images/pcbtutorial/trf_fused_pcb_trimmed.jpg
Trabalho finalizado.
http://ultrakeet.com.au/graphics/images/pcbtutorial/etchant_pcbcomplete.jpg
Agora o mais legal mascara de solda. do mesmo jeito que na primeiras partes cria a mascara de solda na impressoa e utliza o método de transferencia termica.
http://ultrakeet.com.au/graphics/images/pcbtutorial/mask_printed.jpg
http://ultrakeet.com.au/graphics/images/pcbtutorial/mask_black_ready.jpg
e depois aquele filme verde de novo que so adere ao toner.
http://ultrakeet.com.au/graphics/images/pcbtutorial/mask_green_ready.jpg
Acho que vou pedir um desses kits na mouser ou digikey e testar depois eu posto meus resultados.
Offline Euclides Júnior
  • Júnior
  • Cidade - UF: Timoteo/MG
Re:Placa pcb método termico
« Resposta #1 Online: 23 de Novembro de 2011, 11:34 »
Amigo o Jost desenvolveu uma técnica igual a esta e muito mais barato, ele fez uma laminadora com sucata de impressora e usa papel de adesivo de etiquetas de uma garimpada no fórum que você encontrara a técnica e a mesma.
Jr.
Offline Blackmore
« Resposta #2 Online: 23 de Novembro de 2011, 12:04 »
além da sucata de impressora, pode tb utilizar aquelas plastificadoras de documentos para fazer a adesão do toner no cobre da pcb, e pode se utilizar papel sulfite com gramatura de 75g até uns 90g porém a temperatura tem que aumentar, ou ainda papel de revista mesmo, aquele mais fino onde é impresso o artigo, a única restrição ... toner original ... com recondicionado há restrições ... ou não funfa.
Offline Guia CNC
  • Cidade - UF: Minas Gerais
  • Nome:: Guia CNC
  • Profissão: Administrador
« Resposta #3 Online: 23 de Novembro de 2011, 12:18 »
Segue o link
http://www.jostdayan.com.br/2008/12/laminadora-para-pci/
Qual o valor desses papéis?
Offline grounyx
« Resposta #4 Online: 23 de Novembro de 2011, 14:13 »
sim bem legal mas o que eu achei interessante foi a mascara de solda de filme verde. Talvez eu compre so o filme termico verde na mouser ou digikey mas so vou faser isso qdo for comprar um lote grande de peças.
