Autor Tópico: Duvida pra ligar Inversor de Frequencia.  (Lida 1128 vezes)
Offline Daniels Fall
  • GUIA CNC BRASIL
  • Cidade - UF: SP
  • Nome:: Daniel
  • Profissão: Robista
« Online: 01 de Agosto de 2018, 15:58 »
 Pessoal, estou com problemas pra ligar este inversor que recebi recentemente..
 Os esquemas estão em anexo.
 Alem dessas ligações, terei que fazer algum ajuste nas configurações do inversor?
  • GUIA CNC BRASIL
  • Cidade - UF: SP
  • Nome:: Daniel
Re:Duvida pra ligar Inversor de Frequencia.
« Resposta #1 Online: 01 de Agosto de 2018, 18:03 »
 As configurações do Spindle..
Parameter:
Speed: 24000rpm
Rated power: 1.5KW
Voltage: 220V
Current: 6A
Frequency: 400Hz
  • GUIA CNC BRASIL
  • Cidade - UF: SP
  • Nome:: Daniel
« Resposta #2 Online: 01 de Agosto de 2018, 18:49 »
 Aqui os parametros do inversor...
https://www.solidrop.net/photo-26/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-18/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-19/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-20/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-21/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-22/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-23/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-24/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
 Aqui os terminais..
https://www.solidrop.net/photo-16/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
https://www.solidrop.net/photo-15/vfd-single-phase-220v-in-and-single-phase-out-zw-at2-frequency-converter-750w-75kw-5a-drive-single-phase-moto-speed.jpg
  • GUIA CNC BRASIL
  • Cidade - UF: SP
  • Nome:: Daniel
« Resposta #3 Online: 02 de Agosto de 2018, 20:52 »
 Alguem poderia só confirmar isso pra mim por favor..
 Para conseguir acionar o spindle pelo mach3 e controlar sua velocidade;
 Primeiro devo configurar esses parametros no inversor..
 setar ambos com valor 2
  E fazer as seguintes ligações..
 10V da  placa  -> VL1 inversor
 ACM      placa  -> COM inversor
 OutPut1 placa  -> CI inversor
 Seria isto mesmo?
 Oque seria este AVI na placa?
