Autor Tópico: ajuda para instalar o ubuntu 8.04  (Lida 7710 vezes)
Offline RUBENS CAMARGO
Offline Eneias Eringer
Re:ajuda para instalar o ubuntu 8.04
« Resposta #17 Online: 15 de Setembro de 2013, 17:16 »
Já usei dessas funcionam perfeitamente!
« Resposta #18 Online: 15 de Setembro de 2013, 17:35 »
Ok caro Eneias !!!!!!
Se eu nao conseguir encontrar por aqui alguma parecida vou encomendar essa dai mesmo!!!
Att:Rubens
« Resposta #19 Online: 15 de Setembro de 2013, 19:56 »
Seria este o arquivo para o mpg2 jog pendante ?
# Jog Pendant
loadrt encoder num_chan=1
loadrt mux4 count=1
loadrt mult2 count=1
loadrt lut5 count=1
addf encoder.capture-position servo-thread
addf encoder.update-counters base-thread
addf mux4.0 servo-thread
addf mult2.0 servo-thread
addf lut5.0 servo-thread
# If your MPG outputs a quadture signal per click set x4 to 1
# If your MPG puts out 1 pulse per click set x4 to 0
setp encoder.0.x4-mode 0
# For velocity mode, set n to 1
# In velocity mode the axis stops when dial is stopped even if that means
# the commanded motion is not completed,
# For position mode (the default), set n to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take,
# This must be set for each axis you want to behave other than default
setp axis.0.jog-vel-mode 0
setp axis.1.jog-vel-mode 0
setp axis.2.jog-vel-mode 0
setp axis.3.jog-vel-mode 0
setp mux4.0.in0 0.01
setp mux4.0.in1 0.001
setp mux4.0.in2 0.0001
setp mult2.0.in0 100
net scale1 mux4.0.sel0 <= parport.1.pin-09-in
net scale2 mux4.0.sel1 <= parport.1.pin-08-in
net pend-scale axis.0.jog-scale <= mux4.0.out
net pend-scale axis.1.jog-scale
net pend-scale axis.2.jog-scale
net pend-scale mult2.0.in1
net rot-scale axis.3.jog-scale <= mult2.0.out
net mpg-a encoder.0.phase-A <= parport.1.pin-02-in
net mpg-b encoder.0.phase-B <= parport.1.pin-03-in
net mpg-x axis.0.jog-enable <= parport.1.pin-04-in
net mpg-y axis.1.jog-enable <= parport.1.pin-05-in
net mpg-z axis.2.jog-enable <= parport.1.pin-06-in
net mpg-4 axis.3.jog-enable <= parport.1.pin-07-in
net pend-counts axis.0.jog-counts <= encoder.0.counts
net pend-counts axis.1.jog-counts
net pend-counts axis.2.jog-counts
net pend-counts axis.3.jog-counts
# Turn on the jog led if any jog axis is enabled
setp lut5.0.function 0x116
net mpg-x lut5.0.in-0
net mpg-y lut5.0.in-1
net mpg-z lut5.0.in-2
net mpg-4 lut5.0.in-3
setp lut5.0.in-4 0
net jog-on parport.1.pin-01-out <= lut5.0.out
A qual local ele deve ser destinado para que funcione ?
Att:Rubens
« Resposta #20 Online: 15 de Setembro de 2013, 20:00 »
outra coisa queria adicionar os botoes para zerar os eixos alguem me explicaria isto?
Att:Rubens
« Resposta #21 Online: 15 de Setembro de 2013, 22:30 »
olha o meus arquivos ai .
você vai ter que adicionar a porta paralela no arquivo .hal
loadrt hal_parport cfg="0x378 0x1060 in  "
addf parport.1.read base-thread
addf parport.1.write base-thread
addf parport.1.reset base-thread
no manual explica como procurar o endereço da segunda porta , no meu caso o endereço foi 0x1060
« Resposta #22 Online: 16 de Setembro de 2013, 10:47 »
Ola caro Eneias !!!!!
desculpe-me pela burrice mais onde esta este arquivo hal ?
Nao sei nada kkkkk
e estes dois arquivos que passou sao para qual funçao?
Att:Rubens
« Resposta #23 Online: 16 de Setembro de 2013, 19:51 »
Outra pergunta como acessar o programa de configuraçao dos drivers smile com o ubuntu?
E na pergunta anterior era saber em que local se abre o arquivo hal ?
depois de aberto este local como proceder para aplicar estes dois arquivos nele
seria somente colar eles por la?
Att:Rubens
« Resposta #24 Online: 17 de Setembro de 2013, 08:08 »
O programa de configuração dos Smile roda em DOS - Linux não tem DOS
« Resposta #25 Online: 17 de Setembro de 2013, 09:28 »
Nao sei nada kkkkk
Att:Rubens
Tem uma pasta em pasta pessoal/emc2 que tem o nome que você deu pra sua configuração da maquina , dentro dela tem todos arquivos de configuração da maquina (.ini .hal .xml .var )
Não basta colar os arquivos la tem que modificar os seus !!! poste os seus aqui que faço a modificação pra você , mas pra ele funcionar a porta paralela já tem que estar no pc e vc tem que me passar o endereço dela .
Pra achar o endereço da porta paralela tem no manual do emc , procure por second parallel port .
depois que a placa estiver instalada você vai digitar lspci -v no consola dai vai aparecer a lista com todas as placas e dispositivos do pc , ai vc tira um print e posta aqui pra eu ver o endereço e colocar no arquivo .!!!! ok !!!
Parece complicado , mas depois fica fácil!!!!
« Resposta #26 Online: 17 de Setembro de 2013, 11:05 »
Ok eu tenho o cd com a iso para dar o boot para inicializar o programa dos smiles
mais nao consigo faser dar certo.
aprecendo o A como esta abaixo
A:\>
Em seguida eu deveria digitar C ou D determinando o local do dispositivo de leitura correto?
Ficaria assim
A:\>D:
Em seguida
D:\>DIR
Na sequencia
D:\>SMIL101A.EXE e enter ok
Aqueles dois pontinhos depois do D sao obrigatorios
pois nao estou conseguindo dar continuidade porque nao consigo aplicar
os pontinhos depois do D
Att:Rubens
« Resposta #27 Online: 17 de Setembro de 2013, 11:11 »
Ok caro Eneias!!!!!
Primeiro vou adquirir oque precisa depois volto a lhe pertubar ok
Abraços e ate mais!!!
Att:Rubens
« Resposta #28 Online: 17 de Setembro de 2013, 11:25 »
Para pôr os dois pontinhos tenta apertar shift + ç
« Resposta #29 Online: 17 de Setembro de 2013, 12:09 »
Pois é liguei para um amigo e fiz isso mais mesmo assim nao tive
exito pois tentei quase todas as letras do alfabeto para para iniciar
o programa e nao deu kkkk
Att:Rubens
