Autor Tópico: Problemas ao instalar o EMC2 no Ubuntu 8.04  (Lida 2989 vezes)
asv
« Online: 17 de Agosto de 2008, 12:59 »
Olá Pessoal, eu ja tinha o Ubuntu 8.04 instalado aqui na minha maquina e tentei apensa instalar o emc2 pelo script, mas quado tento roda o emc da o seguinte problema:
EMC2 - 2.2.6
Machine configuration directory is '/home/alexandre/emc2/configs/test01'
Machine configuration file is 'test01.ini'
Starting EMC2...
insmod: can't read '/usr/realtime-2.6.24-19-generic/modules/rtai_hal.ko': No such file or directory
Realtime system did not load
Shutting down and cleaning up EMC2...
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -9
NOTE: 'rtapi' kernel module must be loaded
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
/usr/bin/emc_module_helper: Invalid usage with args: remove rtai_ksched
Usage: /usr/bin/emc_module_helper insert /path/to/module.ext [param1=value1 ...]
where module is one of:
   rtai_math
   rtai_sem
   rtai_shm
   rtai_fifos
   rtai_up
   rtai_lxrt
   rtai_hal
   rtai_sched
   rtai_smi
   rtai
   rt_mem_mgr
   adeos
   rtl_time
   rtl_sched
   rtl_posixio
   rtl_fifo
   rtl
   mbuff
the path starts with one of:
   /lib/modules
   /usr/realtime
and the extension is one of:
   .ko
or the module is in the directory /usr/realtime-2.6.24-16-rtai/modules/emc2
OR
/usr/bin/emc_module_helper remove module
where module is one of the modules listed above.
ERROR: Module rtai_hal does not exist in /proc/modules
Cleanup done
cp: impossível criar arquivo comum `/home/alexandre/emc_debug.txt': Permissão negada
cp: impossível criar arquivo comum `/home/alexandre/emc_print.txt': Permissão negada
EMC terminated with an error.  You can find more information in the log files
and
as well as in the output of the shell command 'dmesg' and in the terminal
alguem passou por isso?
Re: Problemas ao instalar o EMC2 no Ubuntu 8.04
« Resposta #1 Online: 17 de Agosto de 2008, 14:12 »
Isto significa que o kernel com o módulo de tempo real não foi carregado ... a máquina pode ter sido inicializada com o kernel original ou o kernel adequado para tarefas em tempo real pode não ter sido instalado ... Verifique nas opções de boot se lá está o kernel magma ...
Outro possível prob é tentar rodar o EMC2 como usuário sem privilégios de administrador, tente rodar a partir do terminal, como root ...
« Última modificação: 17 de Agosto de 2008, 14:13 por C N C N o w ! »
« Resposta #2 Online: 17 de Agosto de 2008, 15:09 »
Definitivamente o kernel RealTime não está instalado.
É possível instalar mas dá muito mais trabalho do que baixar a versão com o emc já pré-instalado.
asv
« Resposta #3 Online: 17 de Agosto de 2008, 22:19 »
Jorge voce tinha razão, eu estava usando o kernel original, por isso não funcionava, valeu pela dica!
gerson.k
« Resposta #4 Online: 19 de Julho de 2010, 22:21 »
Onde posso baixar o EMC 2 e ele tem limitação ou é um programa gratuito?
Obrigado!
« Resposta #5 Online: 19 de Julho de 2010, 23:51 »
Gerson
O Emc2 é Free, 0800, de gratis, não tem nenhuma restrição
http://www.linuxcnc.org/index.php
Um Abraço
