Autor Tópico: Linux em micros antigos?  (Lida 20462 vezes)
Re: Linux em micros antigos?
« Resposta #45 Online: 02 de Julho de 2010, 12:07 »
O resultado é esse:
   Driver      "kbd"
   Driver      "mouse"
Como faz p/ Forçar a resolução ?
Offline m3t4l3ir0
« Resposta #46 Online: 02 de Julho de 2010, 22:42 »
Devia ter ai o driver de video...
digita ai
cat /etc/X11/xorg.conf
e envia o resultado que eu digo onde alterar.
Offline m3t4l3ir0
« Resposta #47 Online: 02 de Julho de 2010, 22:51 »
Se quiser pode tentar usar esse.
Código: [Selecionar]
Section "ServerLayout"
        Identifier     "X.org Configured"
        Screen      0  "Screen0" 0 0
        InputDevice    "Mouse0" "CorePointer"
        InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
        ModulePath   "/usr/lib/xorg/modules"
        FontPath     "/usr/share/fonts/X11/misc"
        FontPath     "/usr/share/fonts/X11/cyrillic"
        FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
        FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
        FontPath     "/usr/share/fonts/X11/Type1"
        FontPath     "/usr/share/fonts/X11/100dpi"
        FontPath     "/usr/share/fonts/X11/75dpi"
        FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
        FontPath     "built-ins"
EndSection
Section "Module"
        Load  "dri"
        Load  "extmod"
        Load  "dbe"
        Load  "record"
        Load  "glx"
        Load  "dri2"
EndSection
Section "InputDevice"
        Identifier  "Keyboard0"
        Driver      "kbd"
EndSection
        Identifier  "Mouse0"
        Driver      "mouse"
        Option      "Protocol" "auto"
        Option      "Device" "/dev/input/mice"
        Option      "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
        Identifier   "Monitor0"
EndSection
Section "Device"
        Identifier  "Card0"
        Driver      "nvidia"
EndSection
Section "Screen"
        Identifier "Screen0"
        Device     "Card0"
        Monitor    "Monitor0"
        SubSection "Display"
                Viewport   0 0
                Depth     24
Modes "1024x768"
        EndSubSection
EndSection
« Resposta #48 Online: 03 de Julho de 2010, 07:56 »
lolata@CNC:~$ cat /etc/X11/xorg.conf
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by failsafeDexconf, using
# values from the debconf database and some overrides to use vesa mode.
# You should use dexconf or another such tool for creating a "real" xorg.conf
# For example:
#   sudo dpkg-reconfigure -phigh xserver-xorg
   Identifier   "Generic Keyboard"
   Driver      "kbd"
   Option      "XkbRules"   "xorg"
   Option      "XkbModel"   "abnt2"
   Option      "XkbLayout"   "br"
   Option      "XkbOptions"   "lv3:ralt_switch"
EndSection
   Identifier   "Configured Mouse"
   Driver      "mouse"
EndSection
Section "Device"
   Identifier   "Configured Video Device"
   Boardname   "vesa"
   Busid      "PCI:2:0:0"
   Driver      "vesa"
   Screen   0
EndSection
Section "Monitor"
   Identifier   "Configured Monitor"
   Vendorname   "Plug 'n' Play"
   Modelname   "Plug 'n' Play"
  modeline  "640x480@60" 25.2 640 656 752 800 480 490 492 525 -vsync -hsync
   Gamma   1.0
EndSection
Section "Screen"
   Identifier   "Default Screen"
   Device      "Configured Video Device"
   Monitor      "Configured Monitor"
   Defaultdepth   24
      Depth   24
      Virtual   640   480
      Modes      "640x480@60"
   EndSubSection
EndSection
   Identifier   "Default Layout"
  screen 0 "Default Screen" 0 0
EndSection
Section "Module"
   Load      "glx"
   Load      "GLcore"
   Load      "v4l"
EndSection
Section "ServerFlags"
EndSection
lolata@CNC:~$
« Resposta #49 Online: 03 de Julho de 2010, 08:02 »
Eu tentei alteral o Xorg.conf pelo editor de texto, mas deu uma mensagem que eu não tinha autorisação para fazer isso.,
« Resposta #50 Online: 03 de Julho de 2010, 08:09 »
Eu vi que na pasta tem um Xorg.conf.2 e esse era o antigo, as configurações de video estão lá, mas não consegui excluir "manualmente" o xorg.conf para poder renomear o antigo.
« Resposta #51 Online: 03 de Julho de 2010, 08:54 »
Consegui restaurar minha maquina, usei o Comando sudo gedit e copiei o config 2 p/ conf normal, deu certo, mas o primeiro pc vou ter que trocar a placa de video.
« Resposta #52 Online: 03 de Julho de 2010, 10:09 »
Consegui acertar o PC novo sem trocar a placa de video, copiei as configurações do xorg.conf do velho e coloquei nele.
Agradeço as dicas.
« Resposta #53 Online: 03 de Julho de 2010, 16:17 »
Tá virando um rato de linux... ;D
Offline m3t4l3ir0
« Resposta #54 Online: 03 de Julho de 2010, 18:44 »
Que bom que resolveu o problema  ;D
Qualquer coisa estamos ai.
« Resposta #55 Online: 03 de Julho de 2010, 18:56 »
m3t4l3ir0
Foi graças as suas dicas que eu cheguei lá
Alebe
Eu tentei de tudo que é forma segir as dicas, mas o bagulho não editava, ai pedi ajuda ao "São Google" e as respostas apareceram
sudo gedit /etc/X11/xorg.conf  e é X11 e não x11, hehhehe
mas o gostoso é isso, não precisa dar a resposta certa, é só apontar mais ou menos a direção e a gente vai, tudo bem que tem hora que vai p/ barranco, (é isso que aconteceu com meu avião hoje).
Um Abraço
« Resposta #56 Online: 03 de Julho de 2010, 23:09 »
Muitas das dúvidas e problemas em relação ao linux/emc são relativas aos comandos que são case sensitive.
Como a maioria começou e viciou no Dos/Windows esquecem que em linux isso é primordial.
Outra recomendação é justamente fazer backup do xorg.conf logo depois da instalação.
Como vc percebeu, ele é fundamental.
Offline m3t4l3ir0
« Resposta #57 Online: 04 de Julho de 2010, 12:01 »
Na verdade o xorg.conf esta saindo de cena, a maioria das distribuições não utiliza mais ele.
Offline Moacir0804
« Resposta #58 Online: 13 de Agosto de 2010, 09:42 »
Surgiu uma lista de atualizações (updates) para meu ubuntu aki. Uma delas vai passar o EMC2 2.2.2 para 2.2.8 eu queria saber se no linux tem aquela opção "restauração do sistema" que o xp tem (iniciar/programas/acessorios/ferramentas do sistema) caso algo dê errado eu possa desfazer todas essas modificações.
Também gostaria de saber como fazer um backup dos arquivos de funcionamento do emc2
« Resposta #59 Online: 13 de Agosto de 2010, 09:49 »
Moacir,
Eu coloco a pasta "HOME" numa partição diferente - assim se precisar reinstalar o sistema, não perco os dados pessoais e algumas configurações...
