Conheça nosso grupo no Facebook - https://www.facebook.com/groups/guiacnc/Grupo GuiaCNC Maker - Atualizado Whatsapp - https://chat.whatsapp.com/BzNO86PhtLeEYZPZaVxIrJ
=== Retirado da documentação feita com o próprio xbuild (FeatureCam) ====== Arquivo: +Mach3-Mill Metrico teste - rev1.0.cnc === G E N E R A L I N F OMACHINE TYPE MILLING DIMENSION METR END OF BLOCK <13><10> DECIMAL POINT . CIRC INTERP MULTIPLE QUADRANT TWO AXIS MACHINE NO RAPID AT 45 DEG. YES USE SEQ MAX NO MAX SEQ 99999CNC FILE EXT. NC MAX SPEED 2500.000000 MAX FEED 700.000000 MIN FEED 0.000000 MAX DPM FEED 360.000000 MIN DPM FEED 0.100000 MAX MACROS 99MACRO TYPE NOT AVAILABLE CALL LOCAL MACRO YES INCL FIRST MACRO NO DO LOCAL COORDS NO DO INCREMENTAL MACROS NO C O M M E N T SMACH3-MILL - rev1.0.CNCMACH3 mills (Metrico). 3 axis. Derived from HAAS.CNC Uses M97 local sub program (macro) calls (DISABLED)Set to use EXACT STOP (G61) instead of CV (G64) M O T I O N C O M M A N D SRAPID G00 LINEAR G01 CIRCULAR CW G02 CIRCULAR CCW G03 M I S C E L L A N E O U S F U N C T I O N SSPINDLE START CW M03 SPINDLE START CCW M04 SPINDLE STOP M05 SPINDLE ORIENT COOLANT OFF M09 COOLANT MIST M07 COOLANT FLOOD M08 COOLANT 3 COOLANT 4 C O M P E N S A T I O N C O M M A N D SCOMPENSATION CANCEL G40 COMPENSATION LEFT G41 COMPENSATION RIGHT G42 COMPENSATION 3D COMPENSATION CANCEL 3D P E C K I N GDRILLING FIXED STEP TAPPING FIXED STEP C Y C L E N A M E SDRILL G81 SPOT FACE G82 DEEP G83 TAP G84 CHIP BREAK G73 BORE (F-D-F) G89 BORE (F-F) G85 BORE (F-S-R) G86 BORE (NO DRAG) G76 Z RAPID RETRACT R PLANE RETRACT C I R C U L A R P L A N E SXY PLANE G17 ZX PLANE G18 YZ PLANE G19 F I V E - A X I SHORIZONTAL MACHINE (STACKED TABLES)Y OF A 0.000000 A FACE FROM B 0.000000 A TO B 0.000000 N U M E R I C R E S E R V E D W O R D SName Ld_Zero Tr_Zero Dec_pnt Uns_val + Sign Format FactorSEQ OFF OFF OFF OFF OFF 5.0 1.000000 X-COORD OFF OFF ON OFF OFF 3.4 1.000000 Y-COORD OFF OFF ON OFF OFF 3.4 1.000000 Z-COORD OFF OFF ON OFF OFF 3.4 1.000000 ARC-X OFF OFF ON OFF OFF 3.4 1.000000 ARC-Y OFF OFF ON OFF OFF 3.4 1.000000 RADIUS OFF OFF ON OFF OFF 3.4 1.000000 S-RAD OFF OFF ON OFF OFF 3.4 1.000000 X-CEN OFF OFF ON OFF OFF 3.4 1.000000 Y-CEN OFF OFF ON OFF OFF 3.4 1.000000 COMP-NUM ON OFF OFF OFF OFF 2.0 1.000000 FEED OFF OFF ON OFF OFF 3.2 1.000000 SPEED OFF OFF OFF OFF OFF 4.0 1.000000 TOOL OFF OFF OFF OFF OFF 2.0 1.000000 NEXT-TL OFF OFF OFF OFF OFF 2.0 1.000000 X-CHANGE OFF OFF ON OFF OFF 3.4 1.000000 Y-CHANGE OFF OFF ON OFF OFF 3.4 1.000000 ZSURF OFF OFF ON OFF OFF 3.4 1.000000 ZRAPID OFF OFF ON OFF OFF 3.4 1.000000 ZCLEAR OFF OFF ON OFF OFF 3.4 1.000000 DEPTH OFF OFF ON OFF OFF 3.4 1.000000 INC-DEPTH OFF OFF ON OFF OFF 3.4 1.000000 ABS-DEPTH OFF OFF ON OFF OFF 3.4 1.000000 STEP1 OFF OFF ON OFF OFF 3.4 1.000000 INC-STEP1 OFF OFF ON OFF OFF 3.4 1.000000 ABS-STEP1 OFF OFF ON OFF OFF 3.4 1.000000 STEP2 OFF OFF ON OFF OFF 3.4 1.000000 DWELL OFF ON OFF OFF OFF 5.3 1.000000 X-VECTOR OFF OFF ON OFF OFF 3.4 1.000000 Y-VECTOR OFF OFF ON OFF OFF 3.4 1.000000 MACRO# ON ON OFF OFF OFF 2.0 1.000000 ABS-ZRAPID OFF OFF ON OFF OFF 3.4 1.000000 ABS-ZCLEAR OFF OFF ON OFF OFF 3.4 1.000000 TOOL-DIAM OFF OFF ON OFF OFF 3.4 1.000000 ROT1-ANSI OFF OFF ON OFF OFF 3.4 1.000000 ROT1-MATH OFF OFF ON OFF OFF 3.4 1.000000 SHIFTX OFF OFF ON OFF OFF 3.4 1.000000 SHIFTY OFF OFF ON OFF OFF 3.4 1.000000 SHIFTZ OFF OFF ON OFF OFF 3.4 1.000000 ANG-DPM OFF OFF ON OFF OFF 3.4 1.000000 ANG-CFEED OFF OFF ON OFF OFF 3.4 1.000000 PITCH OFF OFF ON OFF OFF 3.4 1.000000 OFFSET# OFF OFF OFF OFF OFF 2.0 1.000000 TOOL-LENGTH OFF OFF ON OFF OFF 3.4 1.000000 NO-DRAG-X OFF OFF ON OFF OFF 3.4 1.000000 NO-DRAG-Y OFF OFF ON OFF OFF 3.4 1.000000 TOTAL-ANG OFF OFF ON OFF OFF 3.4 1.000000 START-ANG OFF OFF ON OFF OFF 3.4 1.000000 HELIX-PITCH OFF OFF ON OFF OFF 3.4 1.000000 TPI-PITCH OFF OFF ON OFF OFF 3.4 1.000000 ARC-Z OFF OFF ON OFF OFF 3.4 1.000000 Z-CEN OFF OFF ON OFF OFF 3.4 1.000000 ROT2-ANSI OFF OFF ON OFF OFF 3.4 1.000000 ROT2-MATH OFF OFF ON OFF OFF 3.4 1.000000 OV-LENGTH OFF OFF ON OFF OFF 3.4 1.000000 Z-INDEX-CLR OFF OFF ON OFF OFF 3.4 1.000000 MIN-STEP OFF OFF ON OFF OFF 3.4 1.000000 EXP-LENGTH OFF OFF ON OFF OFF 3.4 1.000000 Z-CHANGE OFF OFF ON OFF OFF 3.4 1.000000 ROT1-WIND OFF OFF ON OFF OFF 3.4 1.000000 ROT2-WIND OFF OFF ON OFF OFF 3.4 1.000000 STEPOVER OFF OFF ON OFF OFF 3.4 1.000000 ANG-FPM OFF OFF ON OFF OFF 3.4 1.000000 ANG-INVTIME OFF OFF ON OFF OFF 3.4 1.000000 NOSE-RAD OFF OFF ON OFF OFF 3.4 1.000000 FINI-ALLOW OFF OFF ON OFF OFF 3.4 1.000000 COMP-VAL OFF OFF ON OFF OFF 3.4 1.000000 ABS-SHIFTX OFF OFF ON OFF OFF 3.4 1.000000 ABS-SHIFTY OFF OFF ON OFF OFF 3.4 1.000000 ABS-SHIFTZ OFF OFF ON OFF OFF 3.4 1.000000 SIDE-LALLOW OFF OFF ON OFF OFF 3.4 1.000000 BOT-LALLOW OFF OFF ON OFF OFF 3.4 1.000000 FSHIFTX OFF OFF ON OFF OFF 3.4 1.000000 FSHIFTY OFF OFF ON OFF OFF 3.4 1.000000 FSHIFTZ OFF OFF ON OFF OFF 3.4 1.000000 INC-MACX OFF OFF ON OFF OFF 3.4 1.000000 INC-MACY OFF OFF ON OFF OFF 3.4 1.000000 INC-MACZ OFF OFF ON OFF OFF 3.4 1.000000 Z-INC OFF OFF ON OFF OFF 3.4 1.000000 X-SRFNORM OFF OFF ON OFF OFF 3.4 1.000000 Y-SRFNORM OFF OFF ON OFF OFF 3.4 1.000000 Z-SRFNORM OFF OFF ON OFF OFF 3.4 1.000000 S T R I N G R E S E R V E D W O R D SEOBSEGM-IDMOTIONP1P2P3P4P5P6P7P8P9COMP-STATFIXTURESPINDLECOOLANTCYCLEDATEPROG-NAMEMCSIDSEG-CMTTOOL-CMTTOOL-IDOP-TYPEOP-PASSTOOL-NAMEPLANEFM-NAMEP10P11P12P13P14P15P16P17P18P19P20P21P22P23P24P25P26P27P28P29P30P31P32P33P34P35P36P37P38P39P40P41P42P43P44P45P46P47P48P49P50P51P52P53P54P55P56P57P58P59P60P61P62P63P64P65P66P67P68P69P70P71P72P73P74P75P76P77P78P79P80P81P82P83P84P85P86P87P88P89P90P91P92P93P94P95P96P97P98P99P100CYCLE-RTRCTUDF-TEXTUDF-COMMENTHOLDER-NAMEMACH-TIMETIMEREGION-DATEBOL L O G I C A L R E S E R V E D W O R D SCW-SPINDLEZ-UPZ-DOWNDRILLINGCOMP-ONCOMP-STARTCOMP-ENDCOMP-MIDINDEXWRAPWRAP-Z-UPWRAP-Z-DOWNIS-WORLDWAS-WORLDFLOAT-TAPRIGID-TAPDEEP-TAPCHIP-TAPZ-CHANGEDXY-PLANEZX-PLANEYZ-PLANEUSE-FIXTUREOFFSET-CHDRILL-CPTEDCYCLE-MACROINDEXINGCYCLE-DONEIS-INC-MACLAST-TOOLX-WRAPY-WRAPIS-ZINDXCLRCOMP-3D-ON S Y S T E M R E S E R V E D W O R D SIFIFNOTTHENENDIFELSEIFELSEIFNOTELSEINCLUDE: P R O G R A M F O R M A T SPROGRAM START FORMAT:% (=============================================)<EOB>(Project: <PROG-NAME> )<EOB>(Compiled: <DATE>)<EOB>(----------------------------------------------)<EOB>(FeatureMILL POST for MACH3 MILL rev1.0 - 03/05/2006)<EOB>(MACH3-MILL - rev1.0.CNC)<EOB>(METRICO - ADRIANO)<EOB>(=============================================)<EOB>(====== Tool No <TOOL> = <TOOL-NAME>)<EOB>(====== Tool No <TOOL> diam. = <TOOL-DIAM>)<EOB>(..... Segment = <SEGM-ID>)<EOB>(..... Operation = <OP-PASS> <OP-TYPE>)<EOB>(=============================================)<EOB>{(Comment = <SEG-CMT>)}<EOB>{(Tool Cmt = <TOOL-CMT>)}<EOB>{N<SEQ> }M91000 (Lead-in Macro for Smithy Setup)<EOB>{N<SEQ> }G40 G49 G17 G80 G61 G71 G90 (Metrico & Exact Stop)<EOB>{N<SEQ> }G00<EOB>{N<SEQ> }T<TOOL> M6<EOB>{N<SEQ> }F<FEED><EOB>{N<SEQ> }G<FIXTURE> X<X-COORD> Y<Y-COORD> S<SPEED> <SPINDLE><EOB>{N<SEQ> }<COOLANT><EOB>{N<SEQ> }G43 H<TOOL> Z<Z-COORD><EOB>TOOL CHANGE FORMAT:(=============================================)<EOB>(====== Tool No <TOOL> = <TOOL-NAME>)<EOB>(====== Tool No <TOOL> diam. = <TOOL-DIAM>)<EOB>(..... Segment = <SEGM-ID>)<EOB>(..... Operation = <OP-PASS> <OP-TYPE>)<EOB>(=============================================)<EOB>{(Comment = <SEG-CMT>)}<EOB>{(Tool Cmt = <TOOL-CMT>)}<EOB>{N<SEQ> }T<TOOL> M6<EOB>{N<SEQ> }G43 H<TOOL> Z<Z-COORD><EOB>{N<SEQ> }S<SPEED> <COOLANT><EOB>{N<SEQ>}<MOTION> X<X-COORD> Y<Y-COORD> Z<Z-COORD> {F<FEED>}<EOB>SEGMENT START FORMAT:(..... Segment = <SEGM-ID>)<EOB>(..... Operation = <OP-PASS> <OP-TYPE>)<EOB>{(Comment = <SEG-CMT>)}<EOB>{N<SEQ> }{<MOTION> }{G<FIXTURE>}{X<X-COORD> }{Y<Y-COORD> }{Z<Z-COORD> }F<FEED> {<COOLANT> }<EOB>PROGRAM END FORMAT:{N<SEQ> }{<MOTION> }G91 Z0 M09<EOB>{N<SEQ> }G40 G49 G17 G80 G61 G71 G90 (Metrico & Exact Stop)<EOB>{N<SEQ> }M91001<EOB>{N<SEQ> }M30<EOB>(----------------------------------------------------------------------)<EOB>(------------------------------ E N D -----------------------------)<EOB>(----------------------------------------------------------------------)<EOB><EOB>RAPID MOVE FORMAT:{N<SEQ> }{<MOTION> }{X<X-COORD> }{Y<Y-COORD> }<EOB>LINEAR MOVE FORMAT:{N<SEQ> }{<MOTION> }{<COMP-STAT> }{X<X-COORD> }{Y<Y-COORD> }{Z<Z-COORD> }{F<FEED> }<IF><COMP-START><THEN>D<COMP-NUM><ENDIF><EOB>CIRCULAR MOVE FORMAT:{N<SEQ> }{<PLANE> }{<MOTION> }<IF><XY-PLANE><THEN>X<X-COORD> Y<Y-COORD> {Z<Z-COORD> }I<ARC-X> J<ARC-Y><ENDIF><IF><ZX-PLANE><THEN>Z<Z-COORD> X<X-COORD> {Y<Y-COORD> }K<ARC-Z> I<ARC-X><ENDIF><IF><YZ-PLANE><THEN>Y<Y-COORD> Z<Z-COORD> {X<X-COORD> }J<ARC-Y> K<ARC-Z><ENDIF>{ F<FEED>}<EOB>OPEN MACRO FORMAT:N99<MACRO#><EOB>CLOSE MACRO FORMAT:{N<SEQ> }M99<EOB>MACRO CALL FORMAT:{N<SEQ> }P99<MACRO#> M97<EOB>IN_MACRO LINEAR MOVE FORMAT:{N<SEQ> }{<MOTION> }{<COMP-STAT> }{X<X-COORD> }{Y<Y-COORD> }{Z<Z-COORD> }{F<FEED> }<IF><COMP-START><THEN>D<COMP-NUM><ENDIF><EOB>IN_MACRO CIRCULAR MOVE FORMAT:{N<SEQ> }{<PLANE> }{<MOTION> }<IF><XY-PLANE><THEN>X<X-COORD> Y<Y-COORD> {Z<Z-COORD> }I<ARC-X> J<ARC-Y><ENDIF><IF><ZX-PLANE><THEN>Z<Z-COORD> X<X-COORD> {Y<Y-COORD> }K<ARC-Z> I<ARC-X><ENDIF><IF><YZ-PLANE><THEN>Y<Y-COORD> Z<Z-COORD> {X<X-COORD> }J<ARC-Y> K<ARC-Z><ENDIF>{ F<FEED>}<EOB>DRILL CYCLE FORMAT:{N<SEQ> }<CYCLE> X<X-COORD> Y<Y-COORD> Z<ABS-DEPTH> R<ABS-ZCLEAR> F<FEED><EOB>SPOT FACE CYCLE FORMAT:{N<SEQ> }<CYCLE> X<X-COORD> Y<Y-COORD> Z<ABS-DEPTH> R<ABS-ZCLEAR> P.2 F<FEED><EOB>DEEP HOLE CYCLE FORMAT:{N<SEQ> }<CYCLE> X<X-COORD> Y<Y-COORD> Z<ABS-DEPTH> R<ABS-ZCLEAR> Q<STEP1> F<FEED><EOB>TAP CYCLE FORMAT:{N<SEQ> }<CYCLE> X<X-COORD> Y<Y-COORD> Z<ABS-DEPTH> R<ABS-ZCLEAR> F<FEED><EOB>BORE (F-F) CYCLE FORMAT:{N<SEQ> }<CYCLE> X<X-COORD> Y<Y-COORD> Z<ABS-DEPTH> R<ABS-ZCLEAR> F<FEED><EOB>CHIP BREAK CYCLE FORMAT:{N<SEQ> }<CYCLE> X<X-COORD> Y<Y-COORD> Z<ABS-DEPTH> R<ABS-ZCLEAR> Q<STEP1> F<FEED><EOB>BORE (F-D-F) CYCLE FORMAT:{N<SEQ>}<CYCLE> X<X-COORD> Y<Y-COORD> R<ABS-ZCLEAR> Z<ABS-DEPTH> P<DWELL> F<FEED><EOB>CANNED MOVE FORMAT:{N<SEQ> }{X<X-COORD> }{Y<Y-COORD>}<EOB>CYCLE CANCEL FORMAT:{N<SEQ> }G80<EOB>Z RAPID MOVE FORMAT:{N<SEQ> }{<MOTION> }{Z<Z-COORD> }<EOB>FILE END FORMAT:%<EOB>BORE (F-S-R) CYCLE FORMAT:{N<SEQ>}<CYCLE> X<X-COORD> Y<Y-COORD> R<ABS-ZCLEAR> Z<ABS-DEPTH> F<FEED><EOB>BORE (No Drag) CYCLE FORMAT:{N<SEQ>}<CYCLE> X<X-COORD> Y<Y-COORD> R<ABS-ZCLEAR> Z<ABS-DEPTH> P<DWELL><BOL> I<NO-DRAG-X> J<NO-DRAG-Y> F<FEED><EOB>SPINDLE FORMAT:DWELL FORMAT:UDF_TEXT FORMAT:
