Autor Tópico: Programas Diversos para CNCs  (Lida 51993 vezes)
Recav
« Online: 10 de Março de 2006, 21:45 »
Postem aqui : Links, sites, FTPs, etc... para dowloads de softwares livres, que sejam uteis para maquinas de CNCs ...
Favor não postarem softwares "PIRATAS" !
Recav
« Resposta #1 Online: 10 de Março de 2006, 21:47 »
Download do Software DesKAM e outros.
http://www.deskam.com/download.html
Offline ShopCNC
  • ShopCNC
  • ShopCNC
    • ShopCNC
  • Cidade - UF: Varginha - MG
  • Nome:: ShopCNC
  • Profissão: E-Commerce
« Resposta #2 Online: 10 de Março de 2006, 21:55 »
Downloads Software TurboCNC !
All of the software listed below is fully functional shareware.  I consider "cripples" to be unethical.
Gear Calculator - Does all the calculations for spur gear sizing per ASME standards.  Runs in Windows and includes a report generator for analysis records.
Task Manager - Simple, robust to-do list program.  Runs in Windows.  Has a sophisticated "polish fire drill" prioritization algorithm that I tested quite heavily in college.
TurboCNC - 8 axis CNC interpreter.  Runs in DOS and provides step/direction or direct phase control on the parallel port.
MiscSim - Windows simulator for a conceptual 4 instruction minimal instruction set microprocessor.
Zbreak - Post-processing utility for performing 2.5D milling operations on machines without a powered Z axis.  Runs in DOS with a command line interface.
Ace Converter - DXF to G-code conversion utility.  Originally published by Yeager Automation.  Runs in Windows.  Open source.
http://www.dakeng.com/software.html
Offline ShopCNC
  • ShopCNC
  • ShopCNC
    • ShopCNC
  • Nome:: ShopCNC
« Resposta #3 Online: 10 de Março de 2006, 22:09 »
Programas diversos !
CNC Simulator
NCnet Lite -FREE DNC
FREE NC Editor
AutoEditNC
CIMCO FEED & SPEED
CONVERT.EXE
Free Book on CAD
CodeShark
TurboCAD Deluxe
TurboCAD Professional
TurboCAD CAD/CAM
RhinoMan FREE
FeatureMILL3D DEMO
http://www.1st-in-cadcam.com/free-software.php
Offline Paulo
    • http://www.ig.com.br
« Resposta #4 Online: 11 de Março de 2006, 12:08 »
Bom dia pessoal,
olha aqui um ótimo simulador que você pode vêr como vai ficar seu trabalho que você criou e é gratis.
http://www.cncsimulator.com/download.shtml
Offline ShopCNC
  • ShopCNC
  • ShopCNC
    • ShopCNC
  • Nome:: ShopCNC
« Resposta #5 Online: 13 de Março de 2006, 21:23 »
Software para esquemas eletronicos e placas de circuito impresso, com router automatico.
http://www.diptrace.com/
Gera aquivos DXF que podem ser convertidos em Gcode.
Nao é gratuito, demo por 30 dias livre!
« Resposta #6 Online: 17 de Março de 2006, 13:47 »
Alguém ai tem o link para o Artcam em português.
Offline Cledson Souza
« Resposta #7 Online: 24 de Março de 2006, 11:39 »
Algué, tem um link para baixar o visual mill, é possivel trabalhar sem registrar? Atte.
Offline Paulo
« Resposta #8 Online: 24 de Março de 2006, 12:41 »
Citação de: "Brenck"
Brenk,
mandei um e-mail pra você.
Digão AMD
« Resposta #9 Online: 24 de Março de 2006, 17:16 »
SALVE GALERA!
Poxa...Paulo, sera que voce tambem me consegue o artcam >>!
Agradecido...
Abracao.
marceloluthier
« Resposta #10 Online: 26 de Março de 2006, 23:02 »
Alguem tem um link para baixar o MARCH1,2,3?
Gerber
« Resposta #11 Online: 26 de Março de 2006, 23:38 »
Citação de: "marceloluthier"
Mercelo,
Procure aqui: http://www.cncbr.com/download.php
Mach2 versão demo em português, mas so aceita até 1000 linhas de G-code.
Gerber
marceloluthier
« Resposta #12 Online: 27 de Março de 2006, 10:18 »
"Valeu!!!!Gerber obrigado cara de coração!!!
marceloluthier
« Resposta #13 Online: 27 de Março de 2006, 23:16 »
"Por favor pessoal,alguem tem um link onde eu possa baixar o programa ""TURBOCAD""já tentei pelo baixaki mas não deu resultados não alguem tem??Obrigado a todos,e parabéns pelo forum!!!
« Resposta #14 Online: 28 de Março de 2006, 07:45 »
Bom dia. Paulo por gentileza vc pd me passar o link para o Artcam? Atte,
