PROJETOS => Projeto - CNC3AX => Tópico iniciado por: thiagospstorm em 16 de Julho de 2014, 21:07
Título: AJUDA, NÃO SEI SE É CONFIGURAÇÃO OU DEFEITO NA PLACA
Enviado por: thiagospstorm em 16 de Julho de 2014, 21:07
Ola Amigos, resolvi pedir ajuda pois estou a muito tempo com esse problema e não consegui resolver, vou tentar explicar bem,
Montei minha 3ax, fiz os testes seguindo o tutorial de montagem e está tudo ok, porém configuro o mach3 (fotos no anexo da configuração) mais o motor não se mexe, fiz um video mostrando http://youtu.be/DAy_amo4WqI (http://youtu.be/DAy_amo4WqI)
A placa comprei no ML feita pela S A Ribeiro CNC3AXU V1.0
Desde já obrigado
(https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F2.bp.blogspot.com%2F-Z5gJJ4SD3OE%2FU8cQ4lz9w4I%2FAAAAAAAAAYA%2FP80mask8TzE%2Fs1600%2Fconf1.bmp&container=blogger&gadget=a&rewriteMime=image%2F*)
(https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F4.bp.blogspot.com%2F-5SE5JeDw2Oo%2FU8cQ4-XTKbI%2FAAAAAAAAAYI%2FeBU-fI880Jk%2Fs1600%2Fconf2.bmp&container=blogger&gadget=a&rewriteMime=image%2F*)
(https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F3.bp.blogspot.com%2F-tzNiCjKH8es%2FU8cQ4zzkJ2I%2FAAAAAAAAAYE%2FXl0yvUP3tTg%2Fs1600%2Fconf3.bmp&container=blogger&gadget=a&rewriteMime=image%2F*)
(https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F1.bp.blogspot.com%2F-dMtk4xcV3ac%2FU8cQ9YJzEYI%2FAAAAAAAAAYY%2FqcQuWEhgD2s%2Fs1600%2Fconf4.bmp&container=blogger&gadget=a&rewriteMime=image%2F*)
(https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F3.bp.blogspot.com%2F-HF9Wz8A1vVY%2FU8cQ_xG2MOI%2FAAAAAAAAAYg%2FmVH3bfiiT2A%2Fs1600%2Fconf5.bmp&container=blogger&gadget=a&rewriteMime=image%2F*)
(https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F2.bp.blogspot.com%2F-k0mp8-3EnUI%2FU8cRAhXt_AI%2FAAAAAAAAAYo%2F5ha5xdUszj8%2Fs1600%2Fconf6.bmp&container=blogger&gadget=a&rewriteMime=image%2F*)
(https://images-blogger-opensocial.googleusercontent.com/gadgets/proxy?url=http%3A%2F%2F2.bp.blogspot.com%2F-9V_57KxWx_w%2FU8cRCPDDEeI%2FAAAAAAAAAYw%2FkTlPREWFWJY%2Fs1600%2Fconf7.bmp&container=blogger&gadget=a&rewriteMime=image%2F*)
Título: Re:AJUDA, NÃO SEI SE É CONFIGURAÇÃO OU DEFEITO NA PLACA
Enviado por: minilathe em 16 de Julho de 2014, 23:15
O vendedor não lhe oferece suporte? Acho estranho isso, pessoas que vendem produtos e deixam seus clientes por conta própria ou por conta de terceiros. Como é a placa CNC3AXU? É igualzinha à CNC3AX?
Enviado por: thiagospstorm em 17 de Julho de 2014, 08:53
Bom dia, obrigado por responder, o vendedor chegou a tirar algumas dúvidas mais não resolveu o meu problema, comprei essa placa no Mercado livre é idêntica a cnc3ax face simples.
Minha configuração está correta ?
Enviado por: minilathe em 17 de Julho de 2014, 16:14
Podem ser várias coisas: problema na porta paralela do PC, problema na placa, no cabo que conecta a placa ao PC, a configuração da porta paralela do PC pode estar inadequada. Primeiramente verfique a configuração da porta no Setup do PC, em seguida tente monitorar (programa parmon) ou acionar a placa através do programa "parmon2000" (parmon está disponível em: http://www.geekhideout.com/parmon.shtml (http://www.geekhideout.com/parmon.shtml)). Meça as tensões de saída na porta paralela. Sua porta é integrada ao PC (placa mãe) ou pertence a uma placa de E/S?
Há algumas dicas sobre o teste aqui:
http://www.machsupport.com/forum/index.php?topic=10546.0;wap2 (http://www.machsupport.com/forum/index.php?topic=10546.0;wap2)
https://www.machsupport.com/forum/index.php?action=printpage;topic=16423.0 (https://www.machsupport.com/forum/index.php?action=printpage;topic=16423.0)
O programa "parmon2000" pode ajudar mais ainda e se encontra em:
http://homepages.engineering.auckland.ac.nz/~amas008/ParMon2000_14/index.html (http://homepages.engineering.auckland.ac.nz/~amas008/ParMon2000_14/index.html)
Enviado por: thiagospstorm em 17 de Julho de 2014, 20:53
Opa estava perdido, você já meu deu uma direção muito obrigado, vou fazer tudo o que disse ai atualizo aqui os resultados, novamente muito obrigado.
Enviado por: thiagospstorm em 21 de Julho de 2014, 19:28
Achei o problema, realmente era a porta paralela, descobri após testar no terceiro pc, o primeiro estava com problema na porta paralela o segundo era 64bits ai não consegui fazer funcionar tbm, já no terceiro funcionou perfeitamente com essas configurações.
Amigos muito obrigado pela ajuda !
Título: Re:AJUDA, NAO SEI SE E CONFIGURACAO OU DEFEITO NA PLACA
Enviado por: BryanMurgeDB em 26 de Dezembro de 2024, 10:52
Be adjacent to us now at 1xBet for the ultimate online cricket betting savoir faire! We bid the best and most moving cricket odds in requital for huge winnings.
Don’t coed visible on the chance to finish first in obese with 1xBet!
Look over our encyclopaedic cricket betting lines and enjoy a incomparable and far-out familiarity like no other.
1xbet (https://refpa7921972.top/L?tag=s_3464116m_355c_2422859&site=3464116&ad=355&r=en/line/cricket)
