Autor Tópico: Projeto Acruwer  (Lida 60446 vezes)
Offline Acruwer
  • Acruwer
Re: Projeto Acruwer
« Resposta #420 Online: 04 de Janeiro de 2008, 10:28 »
Pessoal na loja que vende fresas eles possuem os seguintes tipos:
FRESA TOPO 4C DIN 6527 METAL DURO 08,0mm PÇ
586 FRESA TOPO 2C DIN 327 04,0mm PÇ
587 FRESA TOPO 2C DIN 327 05,0mm C170 PÇ
588 FRESA TOPO 2C DIN 327 06,0mm PÇ
589 FRESA TOPO 2C DIN 327 07,0mm C170 PÇ
590 FRESA TOPO 2C DIN 327 09,0mm C170 PÇ
591 FRESA TOPO 2C DIN 327 10,0mm PÇ
592 FRESA TOPO 2C DIN 327 12,0mm PÇ
593 FRESA TOPO 2C DIN 327 13,0mm C170 PÇ
594 FRESA TOPO 2C DIN 327 14,0mm C170 PÇ
595 FRESA TOPO 2C DIN 327 15,0mm I 1445 PÇ
597 FRESA TOPO 2C DIN 327 17,0mm C170 PÇ
598 FRESA TOPO 2C DIN 327 18,0mm I 1445 PÇ
599 FRESA TOPO 2C DIN 327 20,0mm C170 PÇ
600 FRESA TOPO 4C DIN 844 03,0mm PÇ
601 FRESA TOPO 4C DIN 844 04,0mm C210 PÇ
602 FRESA TOPO 4C DIN 844 05,0mm C210 PÇ
603 FRESA TOPO 4C DIN 844 06,0mm PÇ
604 FRESA TOPO 4C DIN 844 07,0mm PÇ
606 FRESA TOPO 4C DIN 844 09,0mm C210 PÇ
608 FRESA TOPO 4C DIN 844 11,0mm C210 PÇ
609 FRESA TOPO 4C DIN 844 12,0mm PÇ
610 FRESA TOPO 4C DIN 844 13,0mm PÇ
611 FRESA TOPO 4C DIN 844 14,0mm PÇ
612 FRESA TOPO 4C DIN 844 15,0mm C210 PÇ
613 FRESA TOPO 4C DIN 844 16,0mm C210 PÇ
614 FRESA TOPO 4C DIN 844 17,0mm C210 PÇ
615 FRESA TOPO 4C DIN 844 18,0mm I 1501 PÇ
616 FRESA TOPO 4C DIN 844 20,0mm PÇ
1152 FRESA TOPO 2C DIN 327 04,0mm I 0200 PÇ
1153 FRESA TOPO 2C DIN 327 05,0mm I 0200 PÇ
1154 FRESA TOPO 2C DIN 327 06,0mm I 0200 PÇ
1155 FRESA TOPO 2C DIN 327 07,0mm I 0200 PÇ
1156 FRESA TOPO 2C DIN 327 09,0mm I 0200 PÇ
1157 FRESA TOPO 2C DIN 327 10,0mm I 0200 PÇ
1158 FRESA TOPO 2C DIN 327 11,0mm I 0200 PÇ
1159 FRESA TOPO 2C DIN 327 12,0mm I 0200 PÇ
1160 FRESA TOPO 2C DIN 327 13,0mm I 0200 PÇ
1161 FRESA TOPO 2C DIN 327 14,0mm I 0200 PÇ
1162 FRESA TOPO 4C DIN 844 03,0mm I 0400 PÇ
1163 FRESA TOPO 4C DIN 844 04,0mm I 0400 PÇ
1164 FRESA TOPO 4C DIN 844 05,0mm I 0400 PÇ
1165 FRESA TOPO 4C DIN 844 07,0mm I 0400 PÇ
1166 FRESA TOPO 4C DIN 844 13,0mm I 0400 PÇ
1167 FRESA TOPO 4C DIN 844 14,0mm I 0400 PÇ
1168 FRESA TOPO 4C DIN 844 08,0mm I 0400 PÇ
1169 FRESA TOPO 2C DIN 327 08,0mm I 0200 PÇ
1170 FRESA TOPO 4C DIN 844 09,0mm I 0400 PÇ
1171 FRESA TOPO 4C DIN 844 10,0mm I 0400 PÇ
1172 FRESA TOPO 4C DIN 844 11,0mm I 0400 PÇ
1173 FRESA TOPO 4C DIN 844 12,0mm I 0400 PÇ
1246 FRESA TOPO 4C DIN 6527 METAL DURO 03,0mm PÇ
1292 FRESA TOPO 4C DIN 844 06,0mm I 0400 PÇ
1916 FRESA TOPO 2C DIN 327 22,0mm C170 PÇ
1917 FRESA TOPO 2C DIN 327 24,0mm C170 PÇ
1918 FRESA TOPO 2C DIN 327 25,0mm C170 PÇ
1919 FRESA TOPO 4C DIN 844 21,0mm C210 PÇ
1920 FRESA TOPO 4C DIN 844 22,0mm I 1501 PÇ
1921 FRESA TOPO 4C DIN 844 23,0mm C210 PÇ
1922 FRESA TOPO 4C DIN 844 24,0mm C210 PÇ
1923 FRESA TOPO 4C DIN 844 25,0mm C210 PÇ
1924 FRESA TOPO 4C DIN 6527 METAL DURO 04,0mm PÇ
1925 FRESA TOPO 4C DIN 6527 METAL DURO 05,0mm PÇ
1926 FRESA TOPO 4C DIN 6527 METAL DURO 06,0mm PÇ
1927 FRESA TOPO 4C DIN 6527 METAL DURO 10,0mm PÇ
1928 FRESA TOPO 2C DIN 6527 METAL DURO 03,0mm PÇ
1929 FRESA TOPO 2C DIN 6527 METAL DURO 04,0mm PÇ
1931 FRESA TOPO 2C DIN 6527 METAL DURO 08,0mm PÇ
1932 FRESA TOPO 2C DIN 6527 METAL DURO 10,0mm PÇ
1933 FRESA TOPO 2C DIN 6527 METAL DURO 12,0mm PÇ
1945 FRESA TOPO 4C DIN 6527 METAL DURO 12,0mm PÇ
1958 FRESA TOPO 2C DIN 6527 METAL DURO 06,0mm PÇ
2246 FRESA TOPO 2C DIN 6527 METAL DURO 07,0mm PÇ
2295 FRESA TOPO 2C DIN 327 02,0mm C110 PÇ
2296 FRESA TOPO ESFERICO 2C DIN 327 02,0mm 805/1 PÇ
2307 FRESA TOPO 2C DIN 327 10,0mm C170 C/TIN PÇ
2310 FRESA TOPO 2C DIN 327 03,0mm I 1445 PÇ
2311 FRESA TOPO 2C DIN 327 03,5mm I 1445 PÇ
2312 FRESA TOPO 2C DIN 327 04,5mm I 1445 PÇ
2313 FRESA TOPO 2C DIN 327 05,5mm I 1445 PÇ
2314 FRESA TOPO 2C DIN 327 06,5mm I 1445 PÇ
2315 FRESA TOPO ESFERICO 2C DIN 327 03,0mm 1454 PÇ
2316 FRESA TOPO ESFERICO 2C DIN 327 04,0mm 1454 PÇ
2317 FRESA TOPO ESFERICO 2C DIN 327 05,0mm 1454 PÇ
2318 FRESA TOPO 4C DIN 844 02,0mm I 1501 PÇ
2319 FRESA TOPO 4C DIN 844 02,5mm I 1501 PÇ
2320 FRESA TOPO 4C DIN 844 03,5mm I 1501 PÇ
2321 FRESA TOPO 4C DIN 844 04,5mm I 1501 PÇ
2322 FRESA TOPO 4C DIN 844 05,5mm I 1501 PÇ
2323 FRESA TOPO 4C DIN 844 06,5mm I 1501 PÇ
2359 FRESA TOPO 2C DIN 6527 METAL DURO 02,0mm PÇ
2948 FRESA TOPO 2C DIN 327 03,0mm I LONGA 1445.1 PÇ
2949 FRESA TOPO 2C DIN 327 04,0mm I LONGA 1445.1 PÇ
2950 FRESA TOPO 2C DIN 327 05,0mm I LONGA 1445.1 PÇ
2951 FRESA TOPO 2C DIN 327 06,0mm I LONGA 1445.1 PÇ
2952 FRESA TOPO 2C DIN 327 07,0mm I LONGA 1445.1 PÇ
2953 FRESA TOPO 2C DIN 327 08,0mm I LONGA 1445.1 PÇ
2954 FRESA TOPO 2C DIN 327 09,0mm I LONGA 1445.1 PÇ
2955 FRESA TOPO 2C DIN 327 10,0mm I LONGA 1445.1 PÇ
2956 FRESA TOPO 2C DIN 327 12,0mm I LONGA 1445.1 PÇ
2957 FRESA TOPO 4C DIN 844 03,0mm I LONGA 1501.1 PÇ
2958 FRESA TOPO 4C DIN 844 04,0mm I LONGA 1501.1 PÇ
2959 FRESA TOPO 4C DIN 844 05,0mm I LONGA 1501.1 PÇ
2960 FRESA TOPO 4C DIN 844 06,0mm I LONGA 1501.1 PÇ
2961 FRESA TOPO 4C DIN 844 07,0mm I LONGA 1501.1 PÇ
2962 FRESA TOPO 4C DIN 844 08,0mm I LONGA 1501.1 PÇ
2963 FRESA TOPO 4C DIN 844 09,0mm I LONGA 1501.1 PÇ
2964 FRESA TOPO 4C DIN 844 10,0mm I LONGA 1501.1 PÇ
2965 FRESA TOPO 4C DIN 844 12,0mm I LONGA 1501.1 PÇ
3828 FRESA TOPO 4C DIN 844 14,0mm I LONGA 1501.1 PÇ
3829 FRESA TOPO 4C DIN 844 16,0mm I LONGA 1501.1 PÇ
3888 FRESA TOPO DESBASTE 4C DIN 844 08,0mm 1506 PÇ
3889 FRESA TOPO DESBASTE 4C DIN 844 10,0mm 1506 PÇ
3890 FRESA TOPO DESBASTE 4C DIN 844 12,0mm 1506 PÇ
3930 FRESA TOPO 4C DIN 844 03,5mm C210 PÇ
3931 FRESA TOPO 4C DIN 844 04,5mm C210 PÇ
3932 FRESA TOPO 4C DIN 844 05,5mm C210 PÇ
3933 FRESA TOPO 4C DIN 844 06,5mm C210 PÇ
3934 FRESA TOPO 4C DIN 844 07,5mm C210 PÇ
3935 FRESA TOPO 4C DIN 844 08,5mm C210 PÇ
3936 FRESA TOPO 4C DIN 844 09,5mm C210 PÇ
3937 FRESA TOPO 4C DIN 844 19,0mm I 1501 PÇ
4005 FRESA TOPO 4C DIN 844 16,0mm I 0400 PÇ
4025 FRESA TOPO DESBASTE 4C DIN 844 20,0mm 1506 PÇ
4026 FRESA WOODRUFF 19,5 X 3,0mm DIN 850A 1642 PÇ
4103 FRESA WOODRUFF 19,5 X 6,0mm DIN 850B 1641 PÇ
4157 FRESA TOPO 4C DIN 844 10,5mm C210 PÇ
4158 FRESA TOPO 4C DIN 844 11,5mm C210 PÇ
4256 FRESA TOPO ESFERICO 2C DIN 6527 MD 03,0mm PÇ
4257 FRESA TOPO ESFERICO 2C DIN 6527 MD 04,0mm PÇ
4258 FRESA TOPO ESFERICO 2C DIN 6527 MD 05,0mm PÇ
4336 FRESA TOPO ESFERICO 2C DIN 6527 MD 08,0mm PÇ
4352 FRESA TOPO DESBASTE 4C DIN 844 16,0mm 1506 PÇ
4466 FRESA WOODRUFF 22,5 X 4,0mm DIN 850B 1641 PÇ
4467 FRESA WOODRUFF 22,5 X 5,0mm DIN 850B 1641 PÇ
4850 FRESA TOPO 2C DIN 327 16,0mm I 1445 pç
4851 FRESA TOPO 2C DIN 327 20,0mm I 1445 PÇ
4852 FRESA TOPO 4C DIN 844 20,0mm I 0400 PÇ
Pensei em comprar uma de 3mm, qual seria a melhor opção? Com estas referencias consigo saber qual o diametro da pinça que devo utilizar? Obrigado pessoal!!
Offline gimbabf
  • in memoriam
  • in memoriam
Re: Projeto Acruwer
« Resposta #421 Online: 04 de Janeiro de 2008, 12:59 »
    Acruver
   o diâmetro da pinça vai depender da máquina que vc usa, por ex: uma mini drill normalmente usa pinças 3mm ou menores, já a fresa tb depende do serviço que vc vai executar, se for gravar uma de topo esferico se for cortar é melhor uma de topo reto
    Gilberto
Offline Acruwer
  • Acruwer
Re: Projeto Acruwer
« Resposta #422 Online: 04 de Janeiro de 2008, 14:40 »
Offline ssgarbi
Re: Projeto Acruwer
« Resposta #423 Online: 04 de Janeiro de 2008, 15:07 »
Acruwer
Eu uso uma dessas e tá perfeita, usino até aluminio a peça da foto foi feita com ela, e pode ver na parte de cima da peça que dei uma navalhada no codigo G  e digitei G03 em vez de G02, a tupia foi pro lado errado e deu essa desbastada enorme.
« Última modificação: 04 de Janeiro de 2008, 15:11 por ssgarbi »
Offline Acruwer
  • Acruwer
Re: Projeto Acruwer
« Resposta #424 Online: 04 de Janeiro de 2008, 15:12 »
ssgarbi, voce sabe me dizer qual o diametro do buraco aonde vai a pinça? É facil de encontrar pinças pra ela?
Offline ssgarbi
Re: Projeto Acruwer
« Resposta #425 Online: 04 de Janeiro de 2008, 15:14 »
Sim,  furo de 1/4 acho fresas em Sao Jose dos Campos sem problemas, mas só comprei essa em funçao do preço 65 pilas na Florencio e com uma tupia para madeira para fazer molduras que tem um rolamentozinho na ponta, achei o preço muito bom, mas se tivesse opçao compraria em mm.
Offline ssgarbi
Re: Projeto Acruwer
« Resposta #426 Online: 04 de Janeiro de 2008, 15:16 »
Só te aconselho a montar um variador de velocidade, tem no forum, pra usinar madeira se nao tiver, ela queima a fresa com muita facilidade e pago 20 conto cada fresa, nao dá pra perder a toa.
Offline Acruwer
  • Acruwer
Re: Projeto Acruwer
« Resposta #427 Online: 04 de Janeiro de 2008, 15:29 »
Com certeza montarei um variador´de velocidade, acho que tenho um pronto em casa... tem alguma foto das suas fresas e da tupia?
joelzomer
Re: Projeto Acruwer
« Resposta #428 Online: 04 de Janeiro de 2008, 15:37 »
Desculpa eu me meter Acruwer  ;D
Gostaria de perguntar ao ssgarbi ,se voce faz os programas na mão ?
eu vi vc falando em g2 e g3  ???
Offline ssgarbi
Re: Projeto Acruwer
« Resposta #429 Online: 04 de Janeiro de 2008, 15:43 »
Acruwer,
Sim tenho mas nao aqui, estou na empresa, amanha te mando as fotos, pode por aqui mesmo?
Joelzomer,
Sim faço os códigos na mao para usinagem de peças e outros objetos cuja forma seja bem definida
joelzomer
Re: Projeto Acruwer
« Resposta #430 Online: 04 de Janeiro de 2008, 15:59 »
É linguagem iso  ???
voce trabalha no que?
joelzomer
Re: Projeto Acruwer
« Resposta #431 Online: 04 de Janeiro de 2008, 16:03 »
Seu programa seria parecido com esse  ???
Offline YRD
  • MechMate #17
  • Nome:: Yuri - Mechmate #17
Re: Projeto Acruwer
« Resposta #432 Online: 04 de Janeiro de 2008, 16:12 »
Acruwer
Ssgarbi,
Qual o RPM que você utiliza para este corte e qual a profundidade ? Sabe qual a liga deste alumínio ?
Estou pensando na tupia da B&Decker que vai de 8.000 a 30.000. O que você acha dela para trabalhar alumínio ? E a fresa correspondente, quantos cortes ?
Valeu
Offline ssgarbi
Re: Projeto Acruwer
« Resposta #433 Online: 04 de Janeiro de 2008, 16:25 »
YRD
Nao tenho como medir a rotaçao da tupia, mas acredito algo em torno de 12 a 15 K ,  no aluminio tinha a inscriçao 5052 se nao me engano (algo assim), minha fresa é de 4 cortes, passes de 3 décimos para desbaste e 1 para acabamento foi o que usei.
Offline YRD
  • MechMate #17
Re: Projeto Acruwer
« Resposta #434 Online: 04 de Janeiro de 2008, 16:42 »
YRD
 :o ;D Legal pois eu pensei que para cortar chapas de alumínio (só preciso fazer o corte em 2D) precisaria trabalhar a 3500 rpm.
Mas agora estou em dúvida entre as máquinas:
B&D: http://www.submarino.com.br/tool_productdetails.asp?Query=ProductPage&ProdTypeId=15&ProdId=1559725&ST=SR
Makita: http://hiperb.locaweb.com.br/produtos_descricao.asp?codigo_produto=273296
Yuri
Alguma sugestão para cortas chapas de alumínio semelhantes a esta 5052 e com espessura de 0,63mm a 4.9mm ?
