Autor Tópico: Projeto Cnc de 4 eixos "Close Encounters of the third-kind-1977"  (Lida 152202 vezes)
Offline LuthierX
« Resposta #405 Online: 24 de Julho de 2009, 18:41 »
2 A porca do meu fuso se movimenta a 20 mm por revolução (isto porque estou usando redução de 2 p 1, na verdade meu fuso é de passo 10mm).
O que vc tá falando soa estranho ... confira o passo nativo do fuso ...
Se o passo do seu fuso é de fato 10 mm, redutor 2:1 , micropasso 5:1, então a resolução será:
10 / 200 / 5 / 2 = 0,005 mm por passo
ou
200 passos por milímetro
isso é um pouco confuso, ist6o se refere a configuração de aceleração e velocidade ou a resolução?
Motor Tuning:
Finally we’ll get to actually spin some motors. The first thing in the tuning process is to
calculate how many steps per unit of travel we have. This depends on a few things:
In case of a step motor:
• The amount of steps per revolution, most commonly 200.
• The step resolution of the motor drive, full step, half step, 5, 10, 100 micro steps etc.
In case of a servo motor.
• The amount of quadrature counts produced by the encoder on the motor
• The ‘encoder mode’ of the motor drive. 1, 2 or 4 encoder counts.
In both the above cases:
• The reduction ratio between the motor shaft and lead screw.
• And finally, the thread pitch of the screw. (How far the table moves with each rotation
of the screw).
It should be noted that other actuating systems could be used like belts, rack & pinions etc but
here we will use a lead or ball screw as the basis for our calculation. We will do one metric
and one imperial example.
The metric one:
Let’s assume we have a standard step motor with 200 steps per rev. This motor is driven by a
driver set to 5 micro steps per full step. A Gecko G210 from Geckodrive for example. The
motor is directly coupled to the lead screw which has a pitch of 5mm per revolution. That
means the axis will move 5mm for each revolution of the screw.
So we’ll take the motors 200 steps multiply that by the drives 5 micro step. (200 X 5 = 1000)
The drive needs 1000 pulses (or steps) to turn the screw one revolution thus making the axis
move 5mm. So now we take those 1000 steps and divide by the pitch of the screw, which is 5.
(1000 / 5 = 200). In other words we need 200 steps to move one unit or mm.
Offline jvfc
    • http://www.kapbrasil.com
« Resposta #406 Online: 24 de Julho de 2009, 19:05 »
o texto é referente ao ajuste que deve ser feito em primeiro lugar ( resolução ) passo de fuso, redução, etc....
velocidade e aceleração, é o ajuste secundário e este irá variar de acordo com as caracteristicas de peso, eletronica e motores usados.
« Resposta #407 Online: 24 de Julho de 2009, 19:16 »
Ivan,
Não tem nada de errado.
O texto se refere a uma maneira de ajustar o deslocamento do programa isto é, a quantidade de passos para se deslocar uma unidade - o milimetro.
O Mach3 é configurado em milimetros como unidade de deslocamento.
« Resposta #408 Online: 24 de Julho de 2009, 19:45 »
Ivan, aqui, como no jogo do bicho, vale o que está escrito:   ;D
Resolução, neste contexto, é a menor dimensão (distância) que um eixo consegue resolver (percorrer). Isto nada tem a ver com velocidade e aceleração.
Offline LuthierX
« Resposta #409 Online: 24 de Julho de 2009, 20:17 »
Fabio, Jorge, copiado, estou estudando a configuração do mach3 fiz uma única letra no artcam só para fazer um teste, salvei e abri no mach3, dai esta ai o resultado, do primeiro fragmento de vídeo dela funcionando com as limitações do programa com uma veloci8dade bem baixa, que eu ainda pretendo mudar, mas ainda não segue como, da mesma forma não sei como configurar a área útil e outro itens necessários para fazer alguma coisa com ela, neste vídeo minha esposa ficou preparada para apertar o E-Stop, e tentei fazer o filme, vai ai também a configuração do motor no mach3:
&feature=channel_page [/youtube]
Offline pauloms
  • I came in peace
« Resposta #410 Online: 24 de Julho de 2009, 20:26 »
Puxa, o primeiro episódio da série...  :)
Estou esperando pelos próximos !!
« Resposta #411 Online: 24 de Julho de 2009, 20:59 »
Ivan,
Que pos vc usou ao salvar os percursos no artcam?
A interpolação circular esta com muita retomada de velocidade. Isso pode ser melhorado muito com um pos ajustado
E parabens pela máquina.  8)
« Resposta #412 Online: 25 de Julho de 2009, 10:51 »
Ivan,
Numa primeira vista está muito bom - apenas notei que no final do filme, tive a impressão de uma pequena perda, e se os meus instintos estão apurados ainda, diria que é alguma besteirinha na parte eletronica.
Mas antes de falar disso, vamos com calma - adorei a movimentação da sua criatura.
Olhando a imagem da configuração, eu achei que a velocidade ajustada (1350mm/min) está um tanto baixa, mas isso ainda vai depender de diversos fatores, até mesmo da limitação do programa por ainda não estar licenciado, coisa que se resolve fácilmente ;)
Sobre o que o Alebe comenta, de certa forma eu concordo, mas aí há também outros envolvimentos, inclusive algumas configurações que poderemos fazer.
O mais importante está feito, agora é partir para os refinamentos...
Sei que estou sendo repetitivo, mas de novo (e de novo) tenho que tirar o chapéu pra você e seu empenho.
Parabéns!
Offline LuthierX
« Resposta #413 Online: 25 de Julho de 2009, 15:02 »
logo logo...  ;)
Ivan,
Valeu obrigado, na verdade não faço a menor idéia do que é um pos, ainda pretendo estudar o art cam, esta configuração foi feita de forma totalmente intuitiva, mau sei o que eu realmente fiz...
Ivan,
Parabéns!
Obrigado Fabio, aprendi com vocês, e graças a Deus que temos este belo forum como base!
Seu olho clinico lhe mostra muito alem do que eu possa imaginar, o problema das limitações será resolvido com sua ajuda... Bom vamos lá, a ainda muito trabalho a ser feito, hoje pretendo configurar a área útil no mach3, instalar os censores de fim de curso, e fazer novos vídeos, não sei se cera possível alterar a velocidade, o Maximo que consegui colocar foi 1500 mm/mim, não sei se isto é uma limitação ou eu que não estou sabendo configurar, já tenteai diversas configurações diferentes mas não sei bem ao certo como obter a velocidade máxima dela, eu ainda não consegui fazer os motores perder o passo, acho que isso deve acontecer lá pra cima do 10.000 mm/mim, mas não sei como configurar isto ainda
« Resposta #414 Online: 25 de Julho de 2009, 15:30 »
Ivan,
Dê uma olhadinha no seu e-mail...
Offline LuthierX
« Resposta #415 Online: 25 de Julho de 2009, 15:34 »
Fabio eu li este tutorial que você postou em 2007, muito bacana e útil http://www.guiacnc.com.br/index.php?topic=872.0 este processo é o mesmo no mach3, digo os comandos
 - ALT + M para zerar TODOS os eixos juntos (zera o digital da direita)
Para zerar eixos independentemente, primeiro useo "ALT + 1 ou 2 ou 3" (eixos X, Y ou Z respectivamente) e depois "ALT + Z"?
« Resposta #416 Online: 25 de Julho de 2009, 16:03 »
Ivan,
Hmmm - não lembro disso...
Tenho que dar uma olhada no manual e ver o que se pode fazer.
Uma das coisas que eu acho interessante é que em caso de necessidade, poderemos atrribuir teclas (ou conjunto delas) específicas para fazer certas operações, ou mesmo criar algumas...
« Resposta #417 Online: 25 de Julho de 2009, 18:33 »
Ivan,
Olhando de novo a imagem que mostra a janela de ajustes do eixo, notei que está com 1000 passos por unidade de deslocamento...
Talvez seja por isso que não consegue maiores velocidades.
Pelo que me lembro, você comentou que está usando os motores com 5 de micropasso (1000 passos/giro do motor).
Então vejamos - se o fuso é de 10mm de passo, mas ainda tem uma redução de 2:1 entre o motor e o fuso, poderemos dizer que para cada volta do motor (1000 passos) teremos 5mm de deslocamento da porca (10mm / 2 da redução).
Então, isso quer dizer que alí, naquela janela você deve colocar 200 no lugar do 1000.
Aí sim, experimente aumentar a velocidade, e verá que a cousa muda - e muito.
Offline LuthierX
« Resposta #418 Online: 25 de Julho de 2009, 20:31 »
Ivan,
obrigado já havia tentado isto mas vou tentar novamente, fiz outro vídeo e estou postando as fotos das configurações que estou usando no mach3.
No campo step per, tentei usar os seguintes valores 50, 100, 1000 e 2000, com e sem micro passo, porém ainda não consegui acertar as medidas de avanço dos pórticos, I.é, quando o pórtico x se movimenta 100 mm ele mostra lá no visor valores diferentes disto, ou seja, a escala ainda esta errada, logo não acredito que as velocidades mostradas nos campos estejam corretas!
[/youtube]
« Resposta #419 Online: 25 de Julho de 2009, 20:39 »
Ivan,
Bem, acredito que deva ser coisa boba mesmo...pra mim no campo "steps per..." deve ter 200.
Já no campo Velocity, algo como 5000 ou 6000 deve estar de bom talanho - pelas imagens você tentou valores muito altos.
De qualquer maneira, o som dos motores está muito bom...
