Fabio,
Hoje recebi a resposta do Robert,
Pergunta: Can I change the 2 capacitors of 10.000 uf and 66 V, for 2 capacitors of 10.000 and 100V?
I would like to use a transformer of 53VAC that had sent 75VDC after having rectified.
That is possible for (Power Supply Board Ps300), yes or not?
RespostaYou will need to install an external capacitor of about 10,000 MFD and connect the two wires to the power supply board. No one makes a capacitor larger than we have as a replacement on the board.
The power supply board will work with an external capacitor as long as you remove the two on the board.
Faço uma apelo a todos os specialistas que postem seus comentarios, sobre os pós e contras de fazer esta troca...
