Olá pessoal,
Eneias Eringer e F.Gilii, obrigado novamente pela resposta, agora eu entendi o que é driver de micro passo.
Estou adquirindo um spindle com inversor e gostaria da opinião de vocês, é um bom equipamento? eu consigo utiliza-lo com uma placa cnc3ax? e quem já utizou gostou?, etou pretendento importa-los;
Segue abaixo;
Technical Parameters for Spindle Motor 1) Spec: 80*215 mm (Diameter:80mm x Length:215mm)
2) Power: 2.2 KW
3) Voltage: 220V~250V (We also stock 110V~120V item for country like USA and Canada. Please contact us for item stock)
4) Frequency: 400 Hz
5) Speed: 8000-24000 R/min
6) Water Cooling
7) ER20 collet chuck
Runout off: less than 0.005mm
9) Grease Lubrication
Spec. fmm Speed:rmp Power:Kw Voltage:V Current A Freq. Hz Phase
f80x210 24000 2.2 220 8 400 3
Technical Parameters for Variable Frequency Drive Inverter 1) Inpute Voltage: 220±15% (We also stock 380±15%, please contact us for item stock)
2) Output Voltage – 208-240VAC (analogous to Input Voltage)
3) Inpute Frequency: 48-63 Hz
4) Outpute Frequency: 0-400 Hz
5) Inpute Phase: suit for 1 phase input, and also suit for 3 phase input
6) Outpute Phase: 3 phase
7) Item Manufactuer: From a well-known manufacture who manufacture VFD for more than 12 years.
Warranty: 2 years
Obrigado;
Att.
