Autor Tópico: Duvidas com Turbo CNC (TCNC)  (Lida 104534 vezes)
0 Membros e 15 Visitantes estão vendo este tópico.
Landa
Re: Duvidas com Turbo CNC (TCNC)
« Resposta #315 Online: 01 de Setembro de 2007, 10:06 »
Cabral,
Faltou uma informação, o código faz os quadrados centrados em uma placa de 100mm por 100mm.
Offline Paulo
    • http://www.ig.com.br
« Resposta #316 Online: 01 de Setembro de 2007, 12:10 »
Cabral,
tenta este teste, muito faz quadrado,lozango,circulos, transversais e letras,
não dá pra mandar o arquivo zipado, você copia para o bloco de notas.
dakcnc3.0}
{program start}
;MDI Session started: Friday, 3/12/2004 at 11:28:30.72
; Drawing test program to show the capabilities of my CNC machine and make any calibrate
; http:\\www.geocities.com\dsaproject\handicrafts\cnc\cnc_table.html
;This sample test make draw like these :
;               4in x 4in - square box
;               cross line between the square corners
;               make a circle inside the square box
;               make 4 arc to the center
;               make text string 'DSA-CNC'
;               make a double square box cover the text string
N005 M17         ;Enable drive
N010 M03                ;Spindle on
N020 G00 Z-0.25
N030 G01 X4.0 Y0.0      ;Make a square
N040 G01 X4.0 Y4.0
N050 G01 X0.0 Y4.0
N060 G01 X0.0 Y0.0
N070 G01 X4.0 Y4.0      ;Make a cross
N080 G00 Z0.25
N090 G00 X0.0 Y4.0
N100 G00 Z-0.25
N110 G01 X4.0 Y0.0
N120 G00 Z0.25
N130 G00 X2.0 Y0.0      ;Make a square in square
N140 G00 Z-0.25
N150 G01 X4.0 Y2.0
N160 G01 X2.0 Y4.0
N170 G01 X0.0 Y2.0
N180 G01 X2.0 Y0.0
N190 G02 X2.0 Y4.0 R2.0                 ;Make a circle
N200 G02 X2.0 Y0.0 R2.0
N210 G02 X2.0 Y2.0 I0.0 J1.0 F5.0       ;Make an arc to center
N220 G03 X0.0 Y2.0 I-1.0 J0.0 F5.0
N230 G03 X2.0 Y2.0 I1.0 J0.0 F5.0
N240 G02 X2.0 Y0.0 I0.0 J-1.0 F5.0
N250 G00 Z0.25
N260 G00 X5.0 Y0.0      ;Make a char 'D'
N270 G00 Z-0.25
N280 G01 X6.0 Y0.0
N290 G01 X6.0 Y0.5
N300 G03 X5.75 Y0.75 I-0.25 J0.0 F5.0
N310 G01 X5.25 Y0.75
N320 G03 X5.0 Y0.5 I0.0 J-0.25 F5.0
N330 G01 X5.0 Y0.0
N340 G00 Z0.25
N350 G00 X5.25 Y1.75    ;Make a char 'S'
N360 G00 Z-0.25
N370 G03 X5.0 Y1.5 I0.0 J-0.25 F5.0
N380 G01 X5.0 Y1.25
N390 G03 X5.5 Y1.25 I0.25 J0.0 F5.0
N400 G01 X5.5 Y1.5
N410 G02 X6.0 Y1.5 I0.25 J0.0 F5.0
N420 G01 X6.0 Y1.25
N430 G02 X5.75 Y1.0 I-0.25 J0.0 F5.0
N440 G00 Z0.25
N450 G00 X6.0 Y2.0      ;Make a char 'A'
N460 G00 Z-0.25
N470 G01 X5.25 Y2.0
N480 G02 X5.0 Y2.25 I0.0 J0.25 F5.0
N490 G01 X5.0 Y2.5
N500 G02 X5.25 Y2.75 I0.25 J0.0 F5.0
N510 G01 X6.0 Y2.75
N520 G00 Z0.25
N530 G00 X5.5 Y2.0
N540 G00 Z-0.25
N550 G01 X5.5 Y2.75
N560 G00 Z0.25
N570 G00 X5.5 Y3.0
N580 G00 Z-0.25
N590 G01 X5.5 Y3.75     ;Make a char '-'
N600 G00 Z0.25
N610 G00 X5.25 Y4.75    ;Make a char 'C'
N620 G00 Z-0.25
N630 G03 X5.0 Y4.5 I0.0 J-0.25 F5.0
N640 G01 X5.0 Y4.25
N650 G03 X5.25 Y4.0 I0.25 J0.0 F5.0
N660 G01 X5.75 Y4.0
N670 G03 X6.0 Y4.25 I0.0 J0.25 F5.0
N680 G01 X6.0 Y4.5
N690 G03 X5.75 Y4.75 I-0.25 J0.0 F5.0
N700 G00 Z0.25
N710 G00 X6.0 Y5.0      ;Make a char 'N'
N720 G00 Z-0.25
N730 G01 X5.0 Y5.0
N740 G01 X6.0 Y5.75
N750 G01 X5.0 Y5.75
N760 G00 Z0.25
N770 G00 X5.25 Y6.75    ;Make a char 'C'
N780 G00 Z-0.25
N790 G03 X5.0 Y6.5 I0.0 J-0.25 F5.0
N800 G01 X5.0 Y6.25
N810 G03 X5.25 Y6.0 I0.25 J0.0 F5.0
N820 G01 X5.75 Y6.0
N830 G03 X6.0 Y6.25 I0.0 J0.25 F5.0
N840 G01 X6.0 Y6.5
N850 G03 X5.75 Y6.75 I-0.25 J0.0 F5.0
N860 G00 Z0.25
N870 G00 X6.25 Y7.0     ;Make a square box
N880 G00 Z-0.25
N890 G01 X4.75 Y7.0
N900 G01 X4.75 Y-0.25
N910 G01 X6.25 Y-0.25
N920 G01 X6.25 Y7.0
N930 G00 Z0.25
N940 G00 X6.5 Y7.25     ;Make a double square box
N950 G00 Z-0.25
N960 G01 X4.5 Y7.25
N970 G01 X4.5 Y-0.5
N980 G01 X6.5 Y-0.5
N990 G01 X6.5 Y7.25
N1000 G00 Z0.25
N1010 M05               ;Spindle off
N1020 M18               ;Disable drive
N1030 M02               ;End of program
Offline Paulo
« Resposta #317 Online: 01 de Setembro de 2007, 12:14 »
Cabral,
esqueci de dizer, este arquivo foi gerado em polegadas, portanto o TCNC deve estar em polegadas, os quadrados são de 100mm²(4").
Offline Márcio
« Resposta #318 Online: 01 de Setembro de 2007, 15:26 »
Boa tarde aos amigos!
Gente eu to com uma duvida!
EU to usando o tcnc pra controlar minha maquina ....uso uma placa nlabs +a r-evolution estou alimentando a placa com 5v e os motores com 30V.......eu nao sei a potencia dos motores pois nao tem nada escrito.
Minha duvida e a seguinte:
Configurei o TCNC assim:
Acel:15000
Max vel:10000
start 500
jogs 800
Colquei para fazer uma simulaçao em automatico fazendo um trajeto durante 10 vezes e ele fazia em 2m54s
Este manten-se o mesmo a max vel em 4000hz .
Minha duvida eh : se eu aumento a velocidade max nao deveria diminuir o tempo que faz o trajeto?
T+
Marcio :)
« Resposta #319 Online: 01 de Setembro de 2007, 15:47 »
Caro Amigo;
No seu codigo G, deve ter algum parametro que está determinando a velocidade de trabalho.
Esse paramentro começa com a letra F que é a velocidade.
De uma conferida
Offline Márcio
« Resposta #320 Online: 01 de Setembro de 2007, 18:10 »
Lolata!
Nao ha parametro de velocidade no meu codigo G eu apenas fiz este codigo:
x100  y100 z-50
x-100 y-100 z0
e mandei repetir o ciclo 10 vezes
obrigado  :)
Caro Amigo;
De uma conferida
Offline marcusfermino
« Resposta #321 Online: 01 de Setembro de 2007, 18:34 »
Comigo tambem acontece isso. Quando coloco em jog ela vai com a config q eu coloquei acel 40khz e vel max 15khz. Agora quando faço um arquivo assim
g0 x0
g0 x500
g0 x200
g0 x0
ela vai bem mais devagar nem q eu coloque F alguma coisa muda essa velocidade. O que pode ser?
« Resposta #322 Online: 01 de Setembro de 2007, 19:39 »
Quando não se coloca a velocidade F, o turbocnc trabalha com a velocidade padrão.
Esperimente colocar a velocidade e voce vera a diferença.
G1
F500
x0y0
x100y0
x100y100
x0y100
x0y0
depois veja a diferença execultando
G1
F5000
x0y0
x100y0
x100y100
x0y100
x0y0
« Resposta #323 Online: 01 de Setembro de 2007, 20:02 »
Nem assim mudou a velocidade do motor. O que fazer?
« Resposta #324 Online: 02 de Setembro de 2007, 09:41 »
Marcus e Marcio,
A velocidade de avanço - que é controlada pelo programa e que entra em alguns códigos de programação através da letra "F" (de "Feed Rate") pode ser influenciada pelas velocidades máximas...
Um outro detalhe importante é entender que as velocidades de avanço estão sendo exprimidas em "unidades por minuto" (para nós, normalmente milimetros por minuto) enquanto que as velocidades de ajustes de eixos estão em "Hertz" - em frequência...
Há que se converter a frequencia em "mm/minuto" para conhecer ass velocidades máximas de deslocamento do eixo...
Na parte de baixo do quadro onde se informa as frequencias aparecem as velocidades no formato que nos interessa.
Voltando à explicação da Velocidade de Avanço:
Por exemplo, se a velocidade maxima é de digamos 5 metros/minuto, mesmo que se informe uma velocidade de avanço maior (por exmplo 7 metros/min.), esta será limitada pela máxima velocidade da máquina (os 5 metros originais).
As velocidades de Avanço ainda sofrem mais alterações se por exmplo a máquina estiver fazendo "interpolação circular" - então as velocidades de avanço serão proporcionais ao raio de curvatura, e em muitos casos é sempre menor que as velocidades de avanço em interpolação linear...
Offline Márcio
« Resposta #325 Online: 02 de Setembro de 2007, 11:18 »
Ola Fabio!
Era esta mesmo a minha duvida pois eu fiz um teste aumentano a velocidade maxima em hertz ai chegou um ponto que ela nao mudava mais ....por ex: eu colocava 15000hz de velocidade maxima mas quando executava o percurso no final aparecia o mesmo tempo de execução....vou  fazer oq o lolata disse e ver se muda alguma coisa.
Obrigado pela atençao
« Resposta #326 Online: 02 de Setembro de 2007, 11:38 »
Marcio,
A questão é fazer o ajuste no lugar certo!!!
Para alterar a velocidade de CORTE (de avanço), o valor a ser alterado está DENTRO do programa de corte - no arquivo..
Por exemplo, G01 X2222 Y44444 F500(valores de X e Y não valem neste exemplo)
A letra "F" diz que vai usar a função de avanço, e o valor (no exemplo, 500) serão 500 mm/minuto!!!
Cabral
« Resposta #327 Online: 03 de Setembro de 2007, 09:59 »
 :) Landa, Paulo,
Agradeço os códigos,
Vou fazer os testes e posto os resultados.....
Cabral
Cabral
« Resposta #328 Online: 03 de Setembro de 2007, 10:03 »
 ??? Paulo,
Só uma dúvida....
Esse código que vc me passou é para fresadora de 3 motores??? Esse negócio de "J" e "I", não são outros motores? Ou faz parte do código?? Desculpe a pergunta, mas estou começando nos código "G", e ainda não tinha visto isso........
Cabral
« Resposta #329 Online: 03 de Setembro de 2007, 10:08 »
Cabral,
Porque você não experimenta ler o manual do programa???
Tenho certeza que lá explica o que é! ;)
